Re: 50 hr Engine Oil Analysis by Darr
I will try to explain how we utilize oil analysis in naval aviation. Most jet engines are on routine oil analysis, every 10 hrs, 20 , 30 hrs, etc, depending on the age and past history. All engines produce various wear metals (depending on wear surface and bearing designs) and there will always be various amounts in each sample. New engines require an average of three samples in the first several hours to establish their baseline averages. These baseline averages are compared to established tables to see how they fall out. Once we go to the hourly cycles we look for jumps in wear metals that possibly show an increase in wear. The first sample really gives no help but to establish baseline figures. Do not be worried by the fact that you have metals in suspension as this is normal. IMHO unless the oil lab or the dealer can provide you with established metal limits you are not gaining any knowledge unless you routinely provide samples and look for large increases. Just for info military jets use synthetic oils and most never change it until the engine is pulled for major inspections (average 800 flight hours). Sorry to take so long but I used to run oil sample machines and am sold on the idea for aviation.
