Hi, from a newbie.
I've posted a bit of an intro in the New Member Introductions forum.
Every day seems to present a new project; today I'm hanging a one arm loader on my 961.
Loader went on ok; it's attached at the two obvious points. Seems a little wobbly; looks like it would be sturdier with a tie from the bottom of the loader to the underside of the tractor. Should there be another mounting bracket?
I'm controlling (make that "trying to control") the loader with a Selectrol Valve. It's just a single cylinder loader, bucket is gravity controlled, with a trip lever. The Selectrol Valve seems a little sticky, and fussy, and leaky. I've taken it off, and found the little detent ball bearing, and spring, a little rusty and seized. I'm cleaning it up and trying to hone the main bore out some. Seems that even if I get it working properly, it's going to be awkward, at best.
I see Steiner (and others) sell a hydraulic valve adapter (Steiner FD5457), than would bolt on, and give me a 3/8 NPT out and in.
Looks like I could sandwich this between the Selectrol and the tractor (I don't have, or can't find, the orig cover plate).
I think this would allow me to mount a conventional hydraulic control for the loader, and ignore the Selectrol.
Is this the way to go?
Will this allow me to plumb in a rear remote, as well?
