BukitCase
Elite Member
- Joined
- Feb 17, 2012
- Messages
- 2,749
- Location
- Albany OR
- Tractor
- Case 580B, Long 460, Allis-Chalmers 160
Phil, you're entirely welcome - yes, it looks like a fairly simple task to build one of these - here's a pic I found (don't remember where) of a basic subsoiler, looks home made but stout - all you'd need to add would be the pipe laying part, and as I mentioned an electrical conduit "sweep" would make that part pretty easy.
150 meters on a spool might be a bit more of a challenge - you'd want to set up an axle with vertical supports probably using the two lower hitch pins, not sure just how yet - I would start with the spool your pipe comes on and work from there, setting the spool position over your "conduit sweep" so that the pipe feeds straight down into the inlet of the pipe layer part.
With a small tractor, you might need more front counterweights for this because I'm envisioning the spool with the pipe feeding off the FRONT of the spool (closest to the tractor seat) and down. This would put the bulk of the pipe spool behind the subsoil chisel, so your weight balance might be off (although poly pipe isn't REALLY heavy)
Just some thoughts; I've considered building something like this myself, but it hasn't made it to the top of a VERY long list of projects yet
If you're serious about building your own, feel free to run your ideas out so we can pick them apart ...Steve
