John White
I put up a second large building a couple of years ago, 50 x 80. I built it like Johnny Cash's car. One piece at a time as I got the money. Finally got a 500 gal plastic septic tank buried and run all my eves from roof into it for water. Now I am to the point to where I need to get some insulation in my bathroom so I can put a small heater and it will kick on for a few minutes when it gets below 32, to keep my water lines from freezing. When I built the building the posts are 6x6. Metal on outside and on a vapor barrier with osb board on inside. My idea was to have fiber glass insulation blown down between the walls at the top to fill the wall cavity. Which I still may do. But I have come up with a brain storm Idea. Bath room sits in corner. I insulated the two interior walls when I built the bathroom but the two exterior corner walls are not insulated. Here is my idea. I have access to damaged broken blue, pink and white foam board, free. My idea is that I have a old lawn mower on its last leg. I want to take the wheels off. Mount it solid on a 4x4 sheet of plywood, cut a slit about 2" wide and about 12" long across the front of the deck, get a large heavy duty bag, attach it to the chute then just brake the chunks of foam board and shove it through. I would fabricate a small chute about 2" x 12" so I don't get my hands near the blades. I asked a man I seen with a large comercial chipper and asked him about how big would the chips if he run a board of foam through it. He said probably about the size of a large marble. I could just buy a small home yard chipper, but it will only take about a 3"x 3" . I would just climb up on a ladder and pour this foam down the walls.
