AlanB
Elite Member
SG said "No need to be rude to have a simple conversation."
AB said I did not feel I was being rude, you seem to question every response I make as though it is untrue, so I offered to provide further verification and authentication so that I do not appear to be one of those guys that types away on the computer without actually doing what I am referring too.
AB originally said <font color="blue">( Go find New Holland Assit bulletin #443 that says class II boomers (which when I called and spoke with Tech services NH also applied to my 1925) It was referenced here on TBN on the NH forums as I said
http://www.tractorbynet.com/forums/showflat.php/.../353673/ )</font>
SG replied with "That bulletin, taken with the rest of the posts in that section show that the orc is necescary.. due to a DEFECT .. and should not be considdered regular operation. The ORC was a bandaid around the real problem.. which was probably a bearing seized on the tranny countershaft which drove the pot and in that case.. allowed the pto to backfeed the tractor drive train. In normal situations ( correctly functioning machine ).. that wouldn't happen. I believe the answer came down that the unit had been run low on oil allowing either the bearing or aft gear to sieze to the shaft.
This proves nothing.. except NH wanted to bandaid a problem rather than fix it.. whether it is a manufacturing/design problem.. or a user defect doesn't affect the situation any."
AB said I think you should re- read the post, and the NH assist bulletin. If it was for a "failure" then they would just do it on that machine, not take the time to do an assist bulletin and reccomend it across the board. Why would they reccomend to do it all on class II boomers?
SG said "He was running it with no slip clutch and it had a hardened bolt for the shear bolt ( previous owner ). He was told by the previous owner, when he bought the mower and the tractor, that the ORC WAS designed to slip and protect the mower.. obviously it didnt... /forums/images/graemlins/confused.gif the ORC didn't ratched forwad, and instead put a half inch twist in the spline.. and stalled the tractor as the mower stopped on a huge shock load to the drivetrain."
AB said Would you pull apart his ORC and see what kind of condition it is in internally? Or would you send it too me so that I could? I would be willing to cover shipping costs.
I do not know, but I would be willing to bet, that it is siezed inside.
I know this is not edited as nicely as I would like, but I am trying to figure out the color / instant markup thing and not being too sucsessful
