boatmoter
- Joined
- May 3, 2013
- Messages
- 119
- Location
- plant city florida
- Tractor
- john deere 212// john deere 320 // ford 2120 loader
problem with testing for a drain on the later model vehicles, it takes a about 20 minutes for the modules to go to sleep . when you disconnect the battery to hook the meter or test light,the modules wake up and pull voltage, throws your testing off, I use a jumper lead and connect it between the neg post and neg cable, let it sit 20 minutes with everything off,the modules are a sleep by then, then hook your meter up before you remove the jumper lead, then you can get a accurate draw test, I usually use a digital inductive clamp for DC voltage so I don't disturb the modules.. Bob Dillon is right.. the times,there are a changing.. I miss working on the 60's & 70's cars, before I retired the newer cars were driving me nuts.. good luck, also,if you have a radar detector or anything like that plugged into your power point, it may cause a drain,ran across that many times
