I went to Advance this morning after ordering the tune up parts online since that gave me a 20% discount being the day after Black Friday. So for under $100 bucks, I picked up the following:
In the confusion because I picked up a few other items that I did not pre-order, he somehow didn't ring up the 5qt container of synthetic oil!
I did the plugs first and boy were they all super easy to get too! Nothing like a modern car with all that emission stuff on them. I then attempted to do the fuel filter, but the one I picked up, which is supposed to be the OEM one for a 305 (I used a 1977 GMC C1500 since it was an option), was way too long as seen here:
There wasn't a filter in there to begin with, so maybe I'm not putting it in the right spot? So I just reconnected the fuel line with no filter and proceeded to degrease the engine. Here's a shot of the carb once I was done. Perhaps those numbers indicate this being a non-standard carb? Note also that there's a bolt missing from where the carb is mounted to the intake manifold. There is one missing on the other side as well, so perhaps this is not the original 305 carb?
I replaced the distributor, rotor and wires next. Looks half way decent now!
After re-installing the air filter:
I then pored 1/3 pint of seafoam into the almost empty fuel tank, and pored the other 2/3 pint slowly down the carb with the engine running. I then shut it off for 5 minutes and started it back up. Boy did it smoke for a good 3 or 4 minutes! I then jumped in and went for a ride down to the local gas station about 3 miles away. No hesitation at all, and no missing. Ran good and there was no smoke from the exhaust when I got on it. All gauges worked. I filled it up (appears to have a 20 gallon tank) with regular and headed back home.
I then raised the bed and now that the truck was warm, I had no issue getting the pto engaged and then move the other lever to engage the valve. Here's a shot with the bed raised:
Another shot from the other side showing the hydraulic holding tank, and the bling bling hub caps! There is no inline filter, so I'll be sure to change out the hydraulic fluid soon, before I actually have a load to dump. Any ideas on what to use?
Shot from behind showing the well used bed.
I also replaced the headlight switch. That took care of the issue with the high beams being on all the time when the battery is connected (and that red light in the speedometer gauge). Turns out someone has shorted 2 of the pins together on the old switch. I guess they were too cheap to spend the 11 bucks for a new light switch!
While the 305 ran fine, it is no powerhouse in this truck. I had to downshift on any incline and I can only imagine how it would be hauling a full load. Fortunately, I will mostly just be hauling stuff around on my property, spending most of the time in granny 1st, so no big deal. Besides, I got my duramax for any over the road hauling.
So $1200 for the truck and $100 in tune up parts, and this thing is ready to go to work! All I need to do now is to get a 4x8 sheet of plywood, rip it down the middle, paint both pieces black, and bolt then onto the bed to restore the sides that were cut out.
I would like to put a tach in it as I have no idea how high I'm been revving the engine on hills. My gut tells me mid 4000s, but I have have been closer to 5k. I'll look to see if there was a factory option that would drop in that huge opening that is just for the fuel gauge right now.
