Tractor Dr.
- Joined
- Nov 11, 2006
- Messages
- 46
How much play is considered normal in the steering wheel of a new tractor? If I mark a spot on my steering wheel and turn left to right, I have to turn it 2 1/2" to 3" before the front wheels move. Transversely, when driving the tractor I see the wheels move back and forth slightly when the steering wheel is held. Granted the 2 1/2" to 3" doesn't equate to much rotation at the significantly smaller steering shaft. I showed this to the dealer and he said this was actually "better than most L3130's he's seen". He said since it's a hydraulic connection to the steering rack vs. a mechanical connection on cars (rack & pinion gear) so you will see some slop. He said it can't be tightened up. Is the dealer tech giving me a line of BS? Is there a way to get rid of this steering slop?
About 3 years ago I had the same problem on a new B7800, only this became noticeable after about 50 hrs of use. Same dealer (probably different tech) got all of that play out.
