davedj1
Veteran Member
What do you use for sheathing and what thickness? Plywood or new grade of OSB like Advantech or ZIP? I was thinking about using RED ZIP sheathing as the moisture barrier is already applied and all I would need is to tape up the seams. I built a big pump-house using both these products and I am embarrassed to say they have been exposed to the weather for several years with no delamination even on the unprotected edges. My one concern would be I don't think they hold screws as well as plywood.
You would be better off with actual plywood, it has ply's like in it's name where as the OSB is just shavings glued together.
