BHD
Veteran Member
I graded formed and had a 40' X 65' slab poured. I got the "With fiber you don't need rebar" sales pitch.
WELL obviously they never go back and look at the slab 11 years later!
I've got areas that have heaved up or dropped an inch and cracks! And these are areas that I scraped down to level, no fill what so ever!
I think fiber is BS just so the concrete co can get $4. more a yard and the drop and finish crew doesn't have to work around rebar or wire! With rebar and or mesh there is no guessing if will it crack and lift later.
if you have had that much problem your base and preparation was faulty.
if the soil moves under the slab it is going to break the concrete up,
I have seen 75 year old slabs with out any steel mesh or wire, of any type nearly (and hand mixed to boot), with out any major problems and I have seen new that is a disaster in just months, (it like road) if the base is not done properly the top is not going to last long,
and a proper base is not nessarly no fill, but building up the proper bed with the correct soils, (sounds like you have expansive soils or a lot of organic in your soils or both).
all top soils should be removed, and a base built up of non expansive soils and properly compacted,
I worked in Wyoming for a time and in this one location, and there they would dig down 4 or 5 foot, and start with placing up to 12" rocks and then other smaller and then gravel type fill, and properly compacting it as they went and then in theory they would not lift and shift, and even then it was not fool proof. very expansive soils.
saw another thing done from a builder that had worked in expansive soils.
when they did basement frame walls they would cut the frame wall about 3 inches short. and then add a 2x4 to the floor leaving about the distance of tall trim, then they would drive nails between the "Bottom" plate and the plate that was on the slab and the space was so the floor could float up and down and not push the house up an down, the trim was to attach on the bottom plate and the dry wall stop at the bottom of the wall plate, so there the idea was let it float,
one way to have less problem is more small slabs they may not stay even to each other tho, a series of 10 x 10 foot pours,
