Branchchipper
Anyone know of post-hole auger brands out there (cat 1 or 2) with larger "geometry" to allow PTO-shaft clearance on larger tractors? I have an older auger (unk. brand) that works just fine on a MF135D, but because of the height of the arch above the lower links, does not allow proper shaft clearance on an L5030hst. This is not a PTO-shaft length issue, and the arch is adjusted out to the max... (the L5030's 3-pt dimensions are simply wider and taller, aside from the cat 2 pins).
