The couple of contractors I dig for seldom use rebar or wire for sidewalks. They all do put a stone base under the concrete, Some say it's to allow drainage and others use to to get a nice level area for the concrete. For footers most do use 2 or 3 rows of rebar and we always dig a 24" footer and usually pour at least 10" of concrete for the footer. For driveways some use wire, some rebar and others use just fiber in the mix. My shop floor and my front porch both have fiber in it and not one single crack anywhere. I did use a good base and the garage floor was well packed before pouring and even has a 3' diameter hole 6' deep that I set a JIB crane in and it's not even cracked around it.
I think a lot has to do with base prep as to how good the concrete holds up. As they say, concrete will crack but you need to control where you want it to crack at. Homeowners always are anxious to get their driveway and sidewalks poured as soon as the home is done but the settling is not done and usually they end up cracking and or tilting. Also spending a lil bit more and making a 5 1/2" pour instead of a 3 1/2" or 4" pour will help too. Keeping it damp as long as possible while it cures will also help.
Funny things you dig up sometimes when you break up an old driveway, sidewalk or steps. It amazing how many car parts, scrap steel, bed springs and frames, tractor parts, discarded things from a railroad and items I've never seen before end up in concrete. I've not found any guns yet but I'm sure only a matter of time till one shows up.
Topstrap
