George2615
Super Member
There are many types of additives. Those that help prevent gelling or re-liquify gelled fuel say so on the label. Some are just Cetane boosters, some remove water, some are just lubricant adders. I live in the snow belt of NY just a little southeast of Lake Ontario. We see single digit temps many times thru the winter. I had my fuel gel up the first year I owned my latest tractor. Luckily I was able to idle it back into the garage and run a salamander for several hours to get the fuel to re-liquify. Ever since then I have used Power Service additive (the white bottle) which prevents gelling. Power Service 911 in the red bottle also works to de-ice and re-liquify gelled fuel and lines. I do add more than I need to when refilling my tank. I buy my diesel in 5 gallon jugs from a local truck stop (so it is fresh fuel) then dump it into a 16 gallon drum on wheels. That drum has a small trailer battery and a 12V electric pump I use to fill my tractors 8 gallon tank. I don't use a lot of fuel so this setup is a good size for me.
Forgot to mention that when I originally saw my gelled fuel in the fuel bowl it looked like bacon grease after it has cooled and turned white. I don't know what brands of additive TSC sells as I buy mine from the truck stop. If you actually saw a separation line that does indicate water in the fuel. When buying an additive look for one that also removes water.
