Boeing
Platinum Member
"lift the wheels off the ground" Thanks Chiily....THAT had not been mentioned before and might save me lots of ugly words. D
2. Partly dump bucket to about 45 degree angle with the floor when arms are lowered. (Kubota didn't list this one, but I find it helpful). If you don't do this, the stands touch the floor first and can get bent if you keep lowering.
The 854 loader manual does tell you to do this and warns that the support brackets will be damaged if they come in contact with the ground before pulling the two main pins.
Do you have the owner's manual for the loader?
the only other thing it can do is to raise the loader and with the pins removed it shouldn't be able to do that unless something is stuck hard. In fact, when I do this it actually shoves the tractor back or pushes the loader ahead. If you do have a sticky spot this might push it loose.
I'm not even sure how important it is to have flat ground. I took mine off for winter and it's sitting on the lawn. It's sort of level but not like a garage floor. I see it as a practice thing. The more you do it the more you become comfortable doing it.
