Problem with sickle bar lift speed
   / Problem with sickle bar lift speed
Sheepdr; I don' have any other pictures but will take some when I get a chance (and think of it).
I basically replaced the lever mechanism that went under the lift arm with a small piston. I'm sure a one way ram will work for the mower but make sure the valve on the tractor will.
I only mow pasture with mine so less plugging problems. Many times plugging at the end is caused by a gap between the section and guard. Either a worn hold down or the bar that the sections hitch to is bent up at the last section. I also adjust my sway bars (and brake away) so the end away from the tractor is slightly ahead of the tractor side.
Dean
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
STIHL GAS POWERED HAND HELD BLOWER (A58374)
STIHL GAS POWERED...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
