In my case, the symptom was the crankcase oil filling up. I had to drain ~2 qts out the other day to get it back to normal. The oil also smells like diesel and is thin. The coolant is at the proper level...
/ Problems with diesel fuel in crankcase oil - 4320
Ok, I'm not a diesel mechanic but I'm stubborn enough to tackle my own problems when they crop up --- (wife says it ain't stubborn.... it's stupid. Can't spell, either...)
So, what's the "lift pump"? Is that something that is on the newer generation of diesels or a component to the Stanadyne fuel system?
Thanks.
AKfish
The lift pump "lifts" the fuel from the fuel tank and supplies low pressure fuel to the fuel injection pump which supplies high pressure fuel to the injectors.
Hello:
I am dealing with issues with fuel in crank (1958 851 ford diesel,172ci).
- removed injection pump waiting for seal kit(seals do not look deteriorated but will replace with new when they arrive.
- removed injectors found that in order to test you need a tester( built one out of a Hein-werner mod fp-10).
Spec; pop @ 2750psi +- 50, .5" dia fuel spot when held @ 2600psi for 1min, drop from 2200 psi to 1500psi between 6 & 40 sec's.
What I found:
#1 popped @ 2200 psi w/constant drip
#2 popped @ 2400 psi w/dripping
#4 popped @ 2300 psi w/dripping
#3 popped @ 2500 psi w/dripping
solution disassemble clean and recalibrate.
:cool2:
Welcome to TBN! If you don't get an answer from this forum ''this is the John Deere forum'' click on ''forum'' at the top of the page, you will see a Ford forum and also a vintage forum. Good luck!
Edit: Sorry I just reread your post and notice you have found your problem and was just giving the info. :thumbsup:
