You are totally missing the point of what he is trying to accomplish. He is not heating pavement for a patch.
Suddenly I feel I should point out that I'm not a
complete idiot.... :drool:
I read the Original post, and
didn't fail to miss that he was trying to melt ice.
You in turn appear to have failed to read past the first sentence of my post, and totally missed the point
I was trying to make.
My first sentence was simply pointing out that to raise the temperature of a piece of ground takes time - partly thanks to my ability to read, I know that this isn't the OP's actual goal.
Anway........ if the OP requires the ice to melt, and
stay gone, then - whether it's his goal or not - he'll need to get some heat into the ground. Given the massive capacity for stone to hold thermal energy, if he stops heating/melting before he's raised the road surfaces' temperature, that surface is going drop to freezing in very little time.
My point was that "melting the ice" by burning immense amounts of gas is
a) a waste of time,
b) only going to be effective for 2 minutes, and
c) environmentally irresponsible.
In addition - as the driveway in question is gravel - it will not be possible to "burn off" the water. There will always be water in it ready to re-freeze.
You might as well try to keep a 20 meter steel beam at a nice cherry-red with a small blowtorch.
1/8" ice eh? That is the
perfect scenario for grit/sand. :thumbsup:
