RayMunising
In comparing the 3 blowers here's the major differences...
B7800/L3130/Puma64
width: 60/62/64
fan diameter: 17.5/24/20
fan blades: 3/4/4
auger diameter: 14/15/16
cutting depth: 6.75"/6.25"/?
weight: 375/?/382
I don't really know what that all means. The L3130 blower has a much bigger impeller fan diameter (24") than the other two (17.5"/20") and the b7800 has one less fan blade then the other two.
Anyone have any idea what "cutting depth" means? It isn't operating lift height because the b7800 blower lists that as 7.25" (the other 2 blowers don't list operating height) nor is it the transport lift height. I can't really figure out what would be around 6"?
The Puma of course has the major disadvantage of being mounted on the wrong end of the tractor. /forums/images/graemlins/grin.gif
Anyhow, my whole point here is I have this basic premise in my head...
small engine + light/tractor = good for nothing
Small engine + big/heavy tractor = good for ground engaging implements
big engine + light/small tractor = good for powered implements
big engine + big/heavy tractor = can do it all if you have the room & $.
So if the above is true and my primary use for the tractor is snowblowing then I'd be better off with the B7800 with its superior power to weight ratio than a L3130 with its superior weight to power ratio because that'll give more power at the PTO where I need it.
I am also assuming that the specs Kubota lists as PTO hp is with the tractor sitting. It sure would be interesting to know how much HP is available at the PTO when the tractor is in motion!
Several have said their B7800/B2910/B3030 do a great job blowing snow and that's what really counts. I can't thank you enough for taking the time to share your experiences with your machine. So far I haven't heard from a L3130 owner with a front blower that says the same about their machine. I know a L3130 will run rings around a B series when pulling or lifting but HOW ABOUT BLOWING SNOW? And I mean serious snow ... 18 - 24" deep. Munising (where I'll be moving to) gets dumped on from lake effect snow starting in Nov and doesn't quit until April. By March there is typically 4 feet on the ground. On the plus side its a dry fluffy snow ... reminds me of people in Arizona saying "at least its a dry heat". /forums/images/graemlins/grin.gif
Are there any L3130 owners out there with snow blowing experience they'd be so kind as to share with me? /forums/images/graemlins/confused.gif
Thanks to all!!!
PS Ron L - I use a blade on a lawn tractor down here in SE Mich. Works fine for the little bit of snow we get here. /forums/images/graemlins/smile.gif
B7800/L3130/Puma64
width: 60/62/64
fan blades: 3/4/4
weight: 375/?/382
Thanks to all!!!
