JC-jetro said:I belive you but I think that only works if your pto shaft is permenantly splined to the flywheel. I know with dual clutch system you have two shaft splined to two clutch plates. There is an Inner and an outer shaft. The inner shaft is splined to the pto clutch and outer shaft to transmission clutch. What I am not completely sure is if the independent pto is also a dual shaft system that the inner shaft (PTO) is splined permanently to the flywheel and with a PTO clutch pack at the back of the transmission for the pto. As long as engine is running the flywheel will turn no matter what you do to the clutch. Anyone out there to corroborate me on this?
A lot of the independent PTOs we see on CUTs are hydraulically actuated.
