I think there maybe some confusion of the definition of a pull type disc. The pull type discs I see have a set of wheels raised by hydraulic cylinder. There are some very old type pull discs that had no wheels. FWJ are you refering to the type with no wheels?
Discs (wheeled) in the farming world are not near as common anymore. Very good 21' discs with 22" blades and hydraulic wings can be bought for $2-3K. Pull type discs are larger, have more wt and cover more width. 3 pt discs just are too heavy with too much wt far back to be practical for larger tractors. Not sure if I have ever seen a 3 pt bigger than 10'. A wide 3pt large disc would require a lot of front end wt. Weight that doesn't help much but cause compaction when the 3pt is lowered. Much more no till farming today and in my area I don't see a disc in the field very often. A disc will actually increase compaction due to the wt of the tractor going back and forth over the field. Vertical tillage implements are now kind of fashionable in farming. They look like a disc but the discs are more vertical rather than angled like a disc. They can go deep and take a realativley lot of hp even if 18-21' wide.
A pull type disc is much easier to make turns and can follow the land coutour better if have ditches, terraces etc.
FWJ, there is no waste of land on the ends with a pull type, wheel disc. When finished discing, the turn around areas are disced last with pull type. Same as you would do with a 3 pt disc.
That's just like comparing an average sized Kentucky Farm to One in Montana or Alberta.
Most of them would have trouble turning their equipment around on a Kentucky Farm.
I am curious what kind of 8' disc can be pulled by a 20 hp tractor? We have a ~15 footer that no 40 horse is going to pull, but maybe it isn't a good comparison.
So long as it isn't getting any ground penetration, that little tractor might pull it. I'm like you though....20 hp wouldn't even move an 8'er if it were actually IN THE GROUND! I've seen 35 to 40 hp tractors bog down and quit with an 8'er in plowed ground.
Now, if you have an 8' disc with blades worn past service limits, you're discing hard ground where there's virtually no penetration, and that little tractor is a 4wd weighted down to 5,000 or 6,000lbs, 20 hp might pull it at 1 or 2mph..... But then, you aren't really "discing", but just going through the motions
Wow..... Really poor operators in Alberta, huh??
The subject matter of the previous debate was with the old type non-wheeled disc's. The other gentleman (wolc123) seems to think those are better than a transport disc. I have a couple like you're referring to. They work quite well. He's the one with the idea that it's better to leave a wide unworked strip around the lands to turn on. I agree with what you have to say for the most part. I used my wheel disc's to farm with for quite a few years.
I agree with your earlier discussion. I can't figure out why anyone would want a nonwheeled disc, other than price.
