Depending on the length of the run, PVC glued together BEFORE it is put in the ditch will "bow" far more then you would think - even 2" pipe will "curve" so you do not need to use 90's unless you need to turn in a short distance. When you do need a sharper turn, use a "long sweep" when you can or heat the PVC and bend the sweep yourself.
Also, if you can get it, and you are using PVC, use pipe with bells. It will cut down on the number of couplings you need and you would want to install them in the direction you plan to pull.
Anyone that thinks 2" PVC will not bend and bow has never seen a side-boom running 6" or even larger steel pipe into a ditch.
I have never bought PVC conduit that did not have a bell on one end. But than I have only ever bought Carlon brand.
