cmuncy
I have a 30x50x12 steel Mueller building with a 10x12 opening and a walk through door both on one end.
I am in the process of wiring it for electrical and the next step is finishing off some of the walls for a work bench/tool storage and eventually a conditioned space office across the back end.
It seems that for the front part I can fabricate walls on teh ground then slide them up behind the lip on the perlins and secure them to the concrete on the bottom and perlin on the top.
For the back half of the shop, I have the tension wire that extends beyond the perlins so I'd have to make a wall that protrudes further out, thus loosing some floor space.
Does anyone have a good references or pictures of how I might most effectively build these walls?
I'm thinking 1/2" OSB layed horizontally with the remaining top 4+ feet with peg board and probably foam board against the metal skin.
Across the back 30', and 10' out, I plan on building a conditioned work space for my electronics and reloading as well as a small full bathroom.
Thanks guys.
Thanks guys.
