I've done it w/16s. Using a couple 12' 2X4s and cross-braces, screw together a simple a-frame. Spike the apex of the frame to opposite sides of post 4' from top. Put 4' scrap of 1X6 or 2X6 in hole to give bottom of post something to slide against going in. With post lying on ground, place bottom against scrap in hole with a-frame extending away from hole. Starting at top end, raise post over your head, walking toward hole. As you continue to raise, A-frame will support post as it goes up. Remove A-frame from post and repeat...
I used a variation of this technique to erect 2 posts at a time (12' 2X4 on each post). Posts were tied together by top and bottom stringers, which extended in opposite directions to next pair of posts...made squaring up much easier...
Now that I have a BX, I would use FEL to put them up...
