MChalkley
Elite Member
- Joined
- Mar 27, 2000
- Messages
- 3,239
- Location
- Eastern Virginia
- Tractor
- EarthForce EF-5 mini-TLB (2001)
Re: buying new L4610 vs L4310
It's not too complicated, Richie, but it is very important to get it right. I've got OTR 12-16.5's on the front now. I don't recommend them because they're too wide. You have to put a shim on the turn stop up front to keep the wheels from rubbing slightly on the tie rods. In any case, you have to get the wheels from OTR, since they act as Titan's distributor for them (Titan is Kubota's official wheel supplier). I've got a contact at OTR I can give you info on if you email me. If you go with the 19.5LR24 XM27 Michelins, you can use the 11-16 XM27's on the front, but you can't use the stock 16.5 wheels. You have to get 16" diameter wheels instead. If you decide to go with 17.5LR24 XM27's on the back, which is what I'd recommend unless you're prepared to rework an implement connection here or there to get enough clearance, I'll have to check to see what would work on the front. I'll run the numbers and let you know in a bit. You definitely shouldn't run R1's on the front if you use R4's on the back, unless you make absolutely sure of the Rolling Circumferences.
Actually, as far as the traction demo goes, I mentioned the ultimate test I've done in one of my messages on the old board (in the Archives): If I put the Bradco 609 backhoe on the back, all 2,000 pounds of it including the bucket and thumb, and lift all the front loader bucket will hold, I can just barely spin the tires on a hard packed road when pushing against a tree with the engine at 2500 rpm. I figure the tractor weighs just over 11,000 pounds in this configuration. Like I told the guy, if I could get more power to the ground, what would I do with it? And how would I know I had it?
Mark
Mark
