hodoms said:
I have to ask this one last question does the 62D or the 72 mmm fit the tractor better. I know deere list both as options but is the 72 mmm a little too big. I'm looking for real world advice not on a golf course because what if a go a couple weeks in the spring without cutting the grass, the 2210 with 62c would simply chew through the grass no matter the height (might shoot black smoke then keeps mowing). Will 2520 have ample power running a huge 72 inch deck or should I stick with 62D if I decide to buy.
Hodoms I can only speak on behalf of the 2520 with 62D deck. It works really well and the tractor can handle it with plenty of power. When I first got my machine with 62d my grass was left uncut for over a month. The grass was well over 6" and the day I cut it the grass was wet. The 2520 with 62d made the job easy, cutting wet grass from 6 plus inches down to 2.5 had no issues at all. The 2520 with 62d runs like a champ. You will have no issues at all.
In regards to running in high gear, I don't have my wheels filled with liquid. I run in high with just the 62d and 200cx loader minus the bucket. It works on my end.
As for lifting weight, my tractor since day one, brand new only lifted 725lbs plus 300 lbs for bradco ( some users overlooked the fact that I mentioned 725lbs plus the weight of bradco) which brings the figure to around 1000 lbs give or take 50 lbs. As JCMSEVEN posted 1100 lbs is tops he has seen a 2520 lift and I completely agree. With all the 2520 users on here I am sure more users can tune in and offer the real life lift they have experienced. You would think for all the 2520 users in here alot more would be running to defend the lifting of 1800 lbs, not many users in here of 2520 disagreeing with me when I say 1000 to 1100.
The only users that might disagree are the homers that actually think a 2520 is twice the tractor than a 2320 when in reality they are basically the same machine with a few minor tweaks.
If my tractor had pressure line problems it would not lift anything, so I don't think I have any issues with my pressure lines.
Don't listen to the Jehovah Witness of 2520's this tractor will not lift 1800 lbs, not even close. When it comes to real life lifting you need higher height than 1 or 2 inch's, if the tractor can lift up something 1 inch but can't lift it past 2 or 3 feet, that means the tractor can't handle the weight. It's that simple.
Hodoms the thing is some users here buy a machine and become the biggest HOMERS over the unit. They will pump it to all ends and even fabricate stories to make other users think their machine is so much better.
Read the JD manuals and stats, everything is pretty accurate. The only time I hear wild lifting stories are from 2520 owners, never from 2320 owners which have the same lifting power.
Hodoms the machine is a great unit but please understand it is what it is, don't get carried away and don't act like a HOMER thinking it's the end of all ends when it comes to tractors.
If lifting is a major decision, please visit the local JD dealer and try and lift, you are going to find out very fast what the true lift power is on any machine.
Good luck and try the 62d deck out, I think you will have no issues with it's cutting.
