Volfandt
Veteran Member
The 2 used tractors I am most interested in is a B7800 HST with a 72" RFM. And a JD2320 that does not have a mower on it yet.
The B7800 is a whole lot more tractor than the 2320 but they both have similar footprints. In your case, the main advantage I see w/ the 7800 over the 2320 is the 7800 has a 3 range (speed) HST whereas the 2320 only has 2. In your wide open spaces the advantage of chooseing a faster mowing speed goes to the 7800.
The B7800 was the largest of the B class. It has just recently been replaced by the B3200 which is alittle more refined. With the 7800 you get more pto hp, more FEL and 3ph lift capacity and the already mentioned 3 speed HST. The 3ph has a 1/4" valve which is an improvement over the std 3ph control.
The 7800 is also pretty light on it's feet considering it's power. This gives it an advantage in finish mowing and additional weight can be added via implements etc when more weight is needed for ground engagement type work.
The rear wheels of the 7800 can be set out wider to give alittle more stability on hills and you can gain even more stability if you fill the rears with rimguard or similar liquid.
The advantage of the JD2320 is that it has a position control (PC) 3ph which gives it a more precise control of the 3ph implement. You'd have to move up to a "premium" B series (B2630, B3030, B2410, B2910) to get PC.
I would also highly recommend you include an FEL on whatever tractor you choose. They are invaluable in all the chores they'll perform, keeping your back pain free all the while
Since you've already got a riding lawn mower you could use that for "touch up" and close in trimming where the B7800 w/RFM either can't reach or is too slow to manuver around.
Although a MMM is more manuverable, a RFM provides a great finish cut and coupled w/your riding mower you' have a great one/two punch for your estate maintenance.
Good luck
