gizmo
Believe it or not they make plastic welders. The method is similar to tig welding in that you have a heat source and a filler stick. As much as I hate to suggest it, try looking at Harbor Freight.
Plastic Welder
Depending on the type of plastic, you can also try straight MEK. Just dab it on the crack and let it wick itself in. The cracked edges need to be in contact until the MEK evaporates for it to work.
My experience with epoxy on plastic is that it does not stick. However, there may be a formulation specifically for plastic.
Plastic Welder
