jclaudii
- Joined
- Apr 17, 2012
- Messages
- 135
- Location
- River Valley and South Arkansas
- Tractor
- MF35, Kubota7040, Case885, Ford 1100
I am contemplating fixing up an old Long 1199A/B Backhoe and one of the things that will need redone are the hydraulic lines, almost all of them! The manual calls for the 90 Degree Elbows at the Cylinders to be 3/4 -16 So I am guessing this is 3/4 inch hose? Most all of the hoses are deteriorated enough to be through to the steel braiding so getting info off of them is almost impossible.
I am also curious on how much of a "safety margin" should there be in the hydraulic lines? Basically, what PSI rating of hose should I purchase? The hydraulics are self contained with a PTO gearbox that pumps 10GPM with a system relief set at 2000psi and the swing circuit set at 2500psi. I'm just guessing that 3000psi replacement hoses would be good, but I am not sure so I am asking for assistance here. There is single wire, Two wire, flex this, etc and I just need some cheap hoses to get going again. I was going to price buying bulk hose and then just taking that to have fittings put on. I have not looked yet to see if the hoe may have reusable fittings on it or not yet.
Any help is appreciated! Thanks!
