Kirk-NJ
- Joined
- Sep 20, 2009
- Messages
- 411
All of the eyelets or balls on the three point have lost the bearing material. The ball just floats about 3/16" in the arms. Other than replacing the entire arms, can I chop them off and weld on new? What's the typical repair method?
Yes you can cut and weld new ones on. Tractor supply use to carry them.
You tractor is a jubliee/NAA. NOT a 601.
When needing parts tell them 1953 jubilee or 1954 NAA.
The only difference between the two are serial numbers and the nose badge. I stated that your nose badge was changed out on the other site.
Look on the lower section of the block on the left hand side there should be a set of production numbers on it.
Kirk
