Not to bring back an old thread, but I wanted to add a little of my own experience to this and show that things do work in ways you don't think they would sometimes.
Background: I just aquired my grandfathers old 49 8N that he has had since the early 50's. It was used on a regular basis and has only sat for about 2 years as it had several times before. About 5 years ago it had the top end rebuilt, and a new starter put on, which is a 12v starter as we had plans to convert it to a 12v system, but all other parts were still original.
We charged it over night, cleaned up the carb and fuel lines and tried to fire her up by pulling it since the battery didn't seem to have enough juice and that's how we would always do it if she had set for a period of time before. She did spit and sputter and would run under full throttle, but just barely... We had the battery on the charger overnight, but thought we would check the voltage,,,,,, 2 volts.... We figured the generator was having a hard time overcoming that, so off to the store for a new battery. My son took the battery out, so when I went to put the new one back in, the battery terminals didn't fit right, but I've seen that before with old terminals, so I didn't think much of it (not realizing this was to be positive ground). We pulled her again and she fired up and ran pretty decent, but wasn't hitting on all cylinders. Pulled the plugs, cleaned them up and got her running pretty decent. Put probably an hour run time on her and put her up for the night. The next morning, she would only hit on a couple of cylinders but never actually start. The plugs were wet, so I figured they are fouled and such, and new ones would be best. After new plugs, she fired right up and ran quite good. I decided to check the battery and found it wasn't charging and it was getting low, so I started tinkering and that's when I realized this tractor is supposed to be positive ground!!!
I immediately swapped the battery back to positive ground as it should be and she started right back up, but still no charge. I tried to polerize the generator, but couldn't read the terminal on the regulater as it is the original as well, and was pretty dirty. So, instead I just pulled the cover off the regulater, and to my surprise the inside of that thing was spic and span clean! :thumbsup: While she was running, I manually closed one of the relays and got a small spark, but she was then charging. I shut her down and started her back up a couple of times and all appeared to be good, so I buttoned her up and went to work box blading my driveway.
In the end, the coil, lights, and starter worked in reverse polarity,,, even this newer 12V starter. Seems odd I know,,,, but I sure learned alot, and I do electronics for a living as well! These old tractors are definitely bulletproof!
