Sharp_Ranch
- Joined
- Dec 13, 2005
- Messages
- 14
- Location
- Southeastern Oregon
- Tractor
- JD 4320 w/ 400X FEL, Loaded R4's
Congratulations on your new tiller. I have a 6' Howard Rotovator 300 behind my JD 4320 and it does a good job.
One comment: You said the rear trailing board might have a missing part and can come off. That could be a major problem for you if left uncorrected. I know, because I had that happen to me last fall when the trailing board fed itself halfway thru the tines of the tiller before the tractor's PTO shut down after sensing the overload (see picture attached). The cause of the problem was due to the dealer forgetting to install the rear side guards onto the implement which keep the trailing board in its proper lateral position and from coming off its mount. It was a major diassembly task for the dealer to remove the jammed board (but covered by warranty) and the Howard worked fine thereafter.
