OP
joshuabardwell
Elite Member
Just a small update. I did find the nuts where you adjust the air flow and mixture for the oven and the broiler. The oven one was behind the storage drawer on the bottom of the stove and the broiler one is actually inside the oven, just sitting there on the back wall going up to the broiler burner. I still haven't found the thermostat to switch it over. Also, the fitting on the stove's regulator is apparently 3/4" NPT, while the fitting on the propane line is 3/8" flare, so I need an appropriate fitting or fittings to connect those two. Still working on that--my local hardware store didn't have it, but I plan to go back and see if maybe they have two or three fittings that, together, will get me where I need to go.
Also, my local propane supply said that a standard, 10 psi BBQ grill regulator would not be recommended for the range, even though the range has its own regulator too. They recommended a twin-stage one that takes the line pressure all the way down to 11 inches of water column, which is also what the stove runs at. So I got one.
Just dumping these facts here in case someone comes along from Google years from now and is trying to do the same thing.
