Volfandt
Veteran Member
I know he said it ran away. But did it? no Volfant did not make it clearer. I hope this isn't personal with you. It isn't with me.
..... or was it just WOT. Running away means there is no RPM limit and those engines usually just go faster and faster till the destruct (If there is sufficient combustible fuel available). or you can shut it down somehow.
standing beside one of those engines at WOT is is pretty loud. they don't call them screamers for no reason.
I'll try to be as clear as possible....
The valve cover was off for servicing. (replacement of the fuel injectors). One of the new injectors stuck open which inturn jammed the fuel rail at WOT. (It was governed to run at it's governed WOT as it was used to power an AC/DC generator, hydraulic motor to drive itself and another hydraulic pump that was used to pressureize an accumilator that was then used to hydraulically start it. They didn't have electric starters at the time, we added them later tho...).
It was started (not knowing that the injector or fuel rail would jam) and it immediately ran to WOT. Since the valve cover was removed, which also meant the air intake horn to the supercharger was also, this gave the engine oil that was squirting out of the valve train direct access straight into the supercharger, hense the cylinders, which was then providng fuel to run the engine on it's own oil. We shut down the fuel supply which inturn removed the governor, but by this time the engine then "ran away" out of control. Pulling the kill lever had no effect as the fuel rail was stuck open and it was then not running on diesel fuel anyway. Again it was a run-away engine running as fast as it could ungoverned...
We know it ingested rags as we kept stuffing the very short intake horn to the supercharger full until it finally suffocated.
This was over 35 yrs ago but I can still hear that 6-71 Detroit screamming away.....
Dave
