Satoh Replacement Parts
Ignition Parts
Distributor Cap-Echlin (NAPA) Part # EP710
Standard Ignition Part # JH234
Lucas Part # DDJ209
Mazda part#010718202B
Wells Part #
Rotor Echlin (NAPA) Part # EP711
Standard Ignition Part # JR169
Lucas Part # RA77
Mazda Part #
Wells Part #
Points Echlin (NAPA) Part # CS360
Standard Ignition Part # JP8P
Lucas Part #
Mazda Part # 010718210
Wells Part #
Condenser Echlin (NAPA) Part # EP300
Standard Ignition Part # JC34
Lucas Part # DCJ422
Mazda Part #
Wells Part #
Coil Resistor Echlin (NAPA) Part # ICR23
Lucas Part #
Mazda Part #
Wells Part #
Spark Plugs NGK Part # B6E BP6ES Bosh Part # WR7DP
Autolite Part # 64
Champion Part # N4C???
Wire Set Echlin (NAPA) Part # 700172 (7MM 4 cyl)
Lucas Part #
Mazda Part #
Wells Part #
Charging System
Voltage Echlin (NAPA) Part #
Regulator Standard Ignition Part #
Lucas Part #
Mazda Part #
Wells Part #
Transpo Part # IM-952 (
www.transpo.com)
Alternator Part # 14194 (12 volt 35 amp)
Battery Autozone Part #
Part #
Filters
Oil Filter Autozone Part # D332 (Deutsh)
Motorcraft Part # EFL147
AC Delco Part # OF9A
Fram Part #
NAPA Part # 1390
Mazda Part #
Wix Part #
Fuel Filter Autozone Part #
Fram Part #
NAPA Part #
Wix Part #
Air Filter Wix Part # 46270
Belts & Hoses
Inner Belt NAPA Part # (25)7410
Gates Part #
Autozone Part #
Outer Belt NAPA Part # (25)7420
Gates Part #
Autozone Part #
Upper Hose NAPA Part # 8443 (needs trimming)
Gates Part #
Autozone Part #
Lower Hose NAPA Part # 8636 (needs trimming
Gates Part #
Autozone Part #
Cooling System
Water Pump NAPA Part #
Autozone Part #
Part # 1594
Thermostat NAPA Part # 323-180
Gates Part # 33428
Autozone Part #
Mazda Part # 0150030 ???
Gasket Autozone Part #
Fel Pro Part #
Mazda Part #
Fuel System
Fuel Pump Carter Part # M70076
NAPA Part #
Mazda Part #
International Part # 1014262C91
Carburetor International Part # 1014333C1 (gasket set)
Parts International Part # 1014325C1 (accelerator pump)
International Part # 1014086C1 (don’t know what this is)
Federated Part # 30815739B (ONLY THE PUMP IS USABLE !!)
Driveline Parts
Clutch Disc Kubota Part # K66905-13300 (This Kubota replacement has not been
Verified by anyone yet!!)
Pressure Plate Kubota Part # K66591-13400
Throw Out Federal-Mogul Part # 1773
Bearing
Pilot Bearing Federal-Mogul Part # 202-SS
Gaskets
Valve Cover NAPA Part #
Fel Pro Part #
Mazda Part #
Head Gasket NAPA Part #
Fel Pro Part #
Mazda Part #
Exhaust Gasket NAPA Part #
Fel Pro Part #
Mazda Part #
Intake Gasket NAPA Part #
Fel Pro Part #
Mazda Part #
Engine Parts
Piston Rings Hastings Part # 2C4277
Sealed Power Part # E664KC
Thrust Washer Federal Mogul Part # 67392AF (not exact match, 3 out 4 were. It is reported you can use them all, you just have to turn
Them 60 degrees)
Piston Pin Federal Mogul Part # 467394
Bearing Set
Rod Bearings Federal Mogul Part # 4-67355 RA (.25MM , .50MM , .75MM)
