Tinkerman
Well, the grass was a bit long, and there were leaves on the ground -- I hit a surfaced root from an odd angle and busted up a shaft on my Yanmar MMM (fits on a YM 187D). Before I go to a machine shop and pay big $$ to have one fabriated, is anyone aware of a source of supply for Yanmar mower deck parts? It seems that my configuation is not real common...BTW, I bent the shaft and broke the shaft at the base where it's welded to the blade mount.
For reference, the deck is model number YCM 60 A 218-795-0060A. The part needed is the center drive shaft (top pulley driven from the front PTO, and also drives center blade and two splined pulleys for each side's blade). It is a 3/4" shaft, about 7 1/2 inches long (couple inches of keyed groove on the top) with the blade mount welded on the base of it.
While it is late in the season, I still would like to get it repaired since I need the mower deck so I can use my Trac-Vac for the leaves.
If anyone has a recommendation, I would apprecaite it.
Many thanks,
Michael
Many thanks,
Michael
