PILOON
Super Star Member
OK, they actually installed the system so that the poly should self drain. That's good but unless there is a good slope back to the tank it will never empty dry.
Poly comes in coils and it is virtually impossible to lay it perfectly flat. With that 1 1/4" poly it only needs a 1 1/4" dip over the entire run to trap some water.
Poly is shipped in about 3' coils so one coil is +/- 10' long. I defy anyone to uncoil 10' and get a perfectly flat/straight length. Your pics suggested a very low slope between tank and field so I suspect the drain back angle to be slight and the slightest dip in the line would trap water.
All the theories being discussed, effluent generally does not freeze but pure water will.
Are you sure that there is not an excessive amount of pure water entering the field?
Like a leaking toilet float valve? Automatic ice maker?
(don't laugh, my daughter's tank froze up simply due to that. They pumped late fall so there was a lack of bacterial action to heat up the effluent and as a result system froze up. Oh and they had a leaking toilet valve thus mostly pure water in the tank)
LOL, shower less, poop more.
Septic systems are generally sized based on number of bedrooms and that can be a mistake as bigger then requires more bacterial action to be effective. Bacteria will be more active in a contained area and certainly diluted in a huge container.
Oldtimers always suggested dumping macerated pork liver to activate the bacteria in a tank.
I feel for you as I have lived with your type problems either personally or via clients dilemmas.
