Did some maintenance on my BX yesterday. Changed the fluids, no big deal right. I had the parts, read the manual (OK, probably not as good as I should have, when looking at the pics!), it was a nice day, and good to go!
Crawled under looking for the transmission drain plug. I knew it was on the filter side, great. Promptly removed the filter bypass spring plug. UGHHHHHHHHHH! As I removed the spring, the ball fell out, did a coupla circles around my catch pan, and promptly fell through the hole into a quart of old motor oil.
So my first mess was opening the pan can, and dumping the old oil over my hand to catch the ball. SUCCESS. Replaced the filter bypass ball, spring, and plug; Then cleaned my hands, and referred to the manual to see where the drain plug ACTUALLY was located. Good.
Removed the transmission screen to check for debris. HAPPY to see that it only contained a few shavings. As I moved to the garage to clean the debris off with solvent, I ran my oily finger around the screen, and promptly stuck myself with a piece of small mesh wire that was hanging out. OUCH. Fortunately, it bled a lot, which made me feel better about dipping my hand in solvent to remove the oil...................
By now I had most of my tools coated in a layer of oil, making them very fun to operate. Next time, I think I'll skip to step two and just coat them well before I even start working!
Rest of the operation went well and the Bota is now happy with new fluids and filters. The tools are cleaned and my finger only hurts when I type a "d" OUCH!
Hope your maintenance goes better than mine and you get a chuckle from my mis-adventures................
Have fun,
Ron
Have fun,
Ron
