Live in the NW it gets cold here in winters. My shop is 60x40 with half being insulated and having 2 big 12 high doors so sealing them off from the cold is difficult. I installed foam pieced on the inside door panels, also installed a secondary ceiling that is insulated above ,with 12 inch batts, just high enough so to back my dump truck in when needed. Their are three heaters all electric that warms the back section being 24x12 with a stud wall and 8ft sliding door in the middle. I can shut this space off from the front section as this is my lathe, Mill and drill press area that I heat all the time. The second heater out front where my tractors are kept I use an 1000-5000w selectable electric heater that I mounted on a wood dolly so I can move it around, it uses a long piece of 10 gauge SO cord running on 230V and the heater has a good fan drive to blow heat where I need it when working on my equipment. I put power on both side walls to plug the heater into but dont use this hearter a lot, just when it gets to cold for me, about 35-40 these days. This area stays pretty warm being well insulated and with 51/2 inch concrete slab. I also have and use, two big rubber floor matts, the ones used for horse stalls that help keep my feet warmer when around the tractors and such. I just move them where needed and they are great for both walking and knealing when changing tires, oil etc.The last 12x40 section is also walled up and insulated and where I keep all my nand and power tools. It has a 8ft ceiling and is heated via a small electric wall heater with T-stat that keeps the room at 65 all the time same as the lathe room. Above this room is storage for all my junk but for many years was the hay loaf when our girls had horses. Both my Sons grew up in this shop learning lots about machinery, running the lathe, air tools, welding and such and now they are all grown have their own shops and heavy equipment repairing whatever needs it! While many dont need a shop like this one, I felt it justified for my needs and hobbies and it has turned out to work well for my needs.
