Missouri Pioneer
Not exactly an attachments question, but this is where I hang out. If the moderators really want to move it, so be it, but maybe some other folks in this section might be interested.
Unfortunately, our farm has many honey locust trees with the long, nasty thorns which continuously assault our vehicle, trailer, ATV, mower and front tractor tires. I've tried Slime and the dealer's commercial version, and none are up to the task. It's really aggravating when I don't notice the low tire and break the bead, resulting in another trip to the tractor tire shop. Those tractor tires are really heavy. Yes, I've tried the ratchet straps around the tire before trying to pump up the tires, but my compressor at the farm apparently isn't strong enough. (And by the way, my rear tires were filled by the dealer before purchase with some chemical for weight.)
I did have my zero turn mower tires filled with foam and no more flats, but it really makes for a rougher ride.
So, I ask you:
1. Have you had your front tractor tires filled with foam?
2. Are you glad you did it/would you do it again?
3. How much did it cost you? and
4. Where did you have it done?
Thanks.
So, I ask you:
Thanks.
