jaotguy
Veteran Member
the extra 2 wires are : light / exciter circuit and power for the alternator internal reg from the ignition switch (only power when ON )
the power when ON is the 12V for the comparator ( should I charge or not and how much )
the exciter wire and light triggers the alt to charge ..... power thru ignition switch to light then to alt and ground when not running , the light has 12 volts on one side and a ground on the other ..... when it starts to charge, the light now has 12volts on both sides so the light goes out indicating it is charging ...
