Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,246
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
There is a misconception on winch usage that I think should be cleared up.
The idea that using the lower pulley provides down pressure on the winch because the cable is pulling straight down on the top pulley is a common misunderstanding. When you look at it you say "that makes sense". But in reality the same force that is pulling straight down on the top pulley is also pulling straight up on the lower pulley. That means that the net vertical force on the winch from those two forces is zero.
The only force exerted on the winch by the cable is the cable tension at the point of exit. And it is in the direction of the exiting cable. All the internal cable forces cancel each other out. For example, the cable pulls straight up on the drum but it also pulls straight down on the top pulley with an equal force (Cable tension).
The only time you get a downward force on the winch is when the cable exits at a downward angle (ie from the top).
I have attached a paper written by Farmi which makes a statement about this. They recommend winching from the top pulley and skidding from the bottom pulley.
respectfully,
gg
respectfully,
gg
