yelbike
Veteran Member
- Joined
- Nov 7, 2011
- Messages
- 1,639
- Location
- Near Winnipeg, Mb, Canada
- Tractor
- John Deere 2305, 2320,Z465
I understand your point, and I'm all about safety, but there has to be a line somewhere. So you chock the wheels. What if the trailer rolls over the chocks, or the chocks slip? Well, it probably won't do that, but it could. Maybe I should put an anchor in the ground and chain the trailer to the anchor. But the anchor could pull out, so I should put two anchors. Etc... At some point, you have to draw the line and say, "this is safe enough." That's not complacency. It's just common sense. I've parked the trailer on the same pad time and time again. It has never rolled. The pad is almost perfectly level. I have manually dragged the trailer over to the truck to hook it up and I'm aware of exactly how much force is required to start it rolling. Unless gravity changes or something, I can park that trailer on that pad without chocking it without creating a safety risk.
Could it be that when you set your trailer down, your were still moving slowly? Then the trailer just kept on skidding.:confused3:
