motownbrowne
Elite Member
- Joined
- Dec 30, 2013
- Messages
- 2,635
- Location
- river falls, wi
- Tractor
- Kubota mx4700 HST, New Holland TC-29D
If you want to move snow on the cheap, your best option is a back blade, as others have suggested. A light duty one is perfect for snow. Not great for gravel, but fine for snow. My snow moving rig is my New Holland TC29D set up with no loader, a light duty 7' back blade, and tire chains on the front tires. I can move a lot of snow in a hurry. I set the angle off to the side and drive forward. I only have to look behind me if I am backing up to something, or when i sometimes turn the blade around to push banks back. 95% of my operation is done in a forward direction. That's the way everything is designed to be used. We don't usually get more than 6" at a time, and this setup works great for me. If they're forecasting more than 6", I generally go out in the middle of the storm and get the first layer cleared. I wish I had a front mounted blower to work in conjunction with the blade (windrow with the blade, then blow), but for what they cost, I will have to pass for the foreseeable future.
If you want to take it a step higher in the budget, a loader mounted plow will work and allow you to watch what you're doing. One for that size tractor will have to be pretty small though. If you're handy with a welder, I bet you could adapt a truck mounted plow to your tractor frame, which would be a very nice setup, but obviously more involved, and you would probably not be able to use the loader while the plow frame is mounted.
