Harry c
If you're making the hole somewhere you can get at with your tractor, cut the concrete, drill a hole, put in an anchor bolt with a chain attached and simply lift the block out. You can use your FEL or 3 pt to lift. Works great!
Harry c said:If you're making the hole somewhere you can get at with your tractor, cut the concrete, drill a hole, put in an anchor bolt with a chain attached and simply lift the block out. You can use your FEL or 3 pt to lift. Works great!
