OP
Indygunworks
for what its worth the level of light that you see in the picture is 100 percent sunlight coming through the skylights, as I don't have any power on the property yet.
I think that black lead need to go to the battery terminal. If it's after the disconnect it's not gonna charge anything.
No, the disconnect is hooked up to the negative side. I pulled the battery and it tested OK, but needs charge as it was only at 50 percent capacity. Ill have to buy a charger, but hopefully adding the disconnect will keep it from getting that low again.
Also, I looked a the lucas oil engine oil conditioner. Says its supposed to help with cold starts, seems like a good product for what I got going on, any advice?
