OK....more brake issues. Am I the only one that expects the parking brake to actually HOLD the tractor in place on a slope ??
Been having trouble with the parking brake locking good. I already knew what the problem was, just putting off fixing it. I could feel it slipping in the notches that engage the park brake. But today when I had a round bale on the FEL, and parked on a slope, got off to open the gate to the feeder I put my round bales in, and the tractor started to roll. NO GOOD....hate to be rolled over by my own tractor, so to the shop it went.
The problem is the notches in the brake 'pawl'. They were THAT deep to start with, and with some wear, there simply isn't enough metal to hold the brake pedals when you step down. So, off came the pawl again, along with that aggravating round spring, and I took a thin cutting wheel on a hand grinder and cut the notches deeper so the little tit on the left brake pedal will actually have SOMETHING to catch.
This is the pawl, modified. If you look at the right end, that is the original notches by Yanmar. I didn't bother to cut them deeper since the brake doesn't engage on that end anyway....it only starts about mid-way....where I did cut the notches deeper.
While I was under there, I also noticed the spring that is supposed to hold the left brake pedal up in the normal position (one spring on each pedal) was simply flopping around....because the L shaped piece of metal (still on the spring end) that was 'sorta' welded to the pedal shaft wasn't welded anymore.....and in looking at it when I got it off, you could see why. A little tack on each side, and one side had ZERO penetration, so the spring finally broke the other side, which was barely welded on to start with. Wow....some welding job.
See a little holding on the right side, nothing on the left...weld did nothing, no penetration of the pedal shaft.
The "L" piece itself. Again some penetration on the right, none to the shaft on the left. Weld simply popped off with the bracket.
Yeah....and to get TO the pedal shaft, you have to remove the hood cowling (instrument mounting), the fuel lever, all to get to one bolt that goes thru the top of the left pedal shaft. The right pedal simply comes off by removing a half moon clip on the end of the pedal shaft....but NOT the left one ! (which, of course, it the one the spring bracket broke on).
So, about 3 hours of disassembly, welding, painting the welds (went ahead and welded the right pedal bracket while it was off), reassembly.
Grrrrrrrrrr
