LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 10,810
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
thanks
that appears to be a vacuum breaker on top but am curious if it require a down angle from house plumbing?her end has to go into pex
Yes, they need to slope down to the outside. The actual shutoff for that valve is most of the way down in the long extension.speaking of leaving things out to freeze, my second outdoor outlet is merely an extension of the one and only on outside of this cottage.
I run it two inches under mulch around to back side of house. Freezes up every winter.
Thought about what might hold up.
Craftsman 3/4 solid black rubber hose, heavy as can be, so far has lasted two winters without issue. But I do drain the ends well. But it's buried under the gardens and
I just leave it in. I'm figuring five years with the freeze/thaw cycle here. Everything moves around.
unless temps are below mid twenties for a while, usually not a problem.
Sigarms, I've watched all my older family and my wife die of cancer. Slowly.
you and I are on the same page. I've already had cancer, and so far beat it.
but if it comes back, I'm thinking of the Out Islands in the Bahamas for a final cruise.
With a suitcase of pills. The last couple of weeks are just awful on everyone.
I want to check out on a high and on my terms. Realistically, that isn't likely.
speaking of Southerners getting confused....
spent most of my life in PA, but also 7 years in coastal NC and 3 years in North Miami. Lived on a boat in FL.
Had to watch the temps in NC, got cold enough at times to drain the hoses.
do frost free hose bibs really work? Is that just a vacuum release of some sorts that lets the water drain more fully?
would changing a basic spigot valve accomplish anything if the water is right on the other side?
I'm clearly not a plumber...
spent enough years as volunteer fireman to know how to drain a hose...but have lost of bunch of hose nozzles by forgetting to take them off.
Boy do they crack in a heartbeat. This year I remembered...two nozzles in basement.
had to chuckle, went through car wash yesterday thinking of this thread. Extra wax please, I think it lubes the car better and less scratching.
14 bucks. 7 bucks for economy no frills. But that includes drying off, which is where all the benefit is. So my normal car wash during the winter is 14 plus 2.
those two guys at the end drying cars looked pretty tired and it was only noon.
All that road salt means job security for them.
had to be careful pulling out on street when done, below freezing still and water on the street, those wet tire tracks. wet or ice?... wet.
