I use the 12V pump (also have the PTO pump hanging up in the shed) on a boom sprayer I built, and with four spray nozzles and a 30 gal tank, I couldn't ask for a better rig. I run it around 18-20 psi. Earlier this summer I added a hand wand and could spray brush back 30' off the roadway. I didn't expect that of it, and planned only to do spot spraying where I couldn't drive between my trees.
I found, after a couple roller PTO pumps that the maintenance was a bit on the expensive side, although the higher psi was sometimes beneficial, when reaching up into trees. I don't go there anymore. The 12V pump is good for caring for the 8 acres of lawn (just came in from fininshing spraying 180 gal of herbicide as the dandelions and thistles seem to be starting to grow again) and much quicker and easier to hook up and be spraying (just plug it in). Rigging the PTO pump and the hoses and the tanks and going only where my 'bigger' tractor would go, just isn't worth the extra effort to me now. /forums/images/graemlins/wink.gif
