AKfish
Super Member
- Joined
- Oct 1, 2004
- Messages
- 5,417
- Location
- Alaska
- Tractor
- JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
Yes people do seperate fields of each, or some are mixed. Either way works depending on the orchard variety and the timothy variety. If the Ograss is a late maturity and the timothy is an early timothy, they get closer anyway.
As to the field blowing in the wind. Welcome to hay making where some one else does your stuff. This situation is common and it stinks for you and your horses. The hay is still edible if made dry and not rained on, but you can hopefully do better next year. Couple options here. First, just go ahead and make it. It will not be pretty, the nutrition will be low, but the field will get a great over seed (Silver lining). If it is made soon, and you are getting some rain, you still have plenty of time to get a good second cutting. Second, let it stand a little longer if you are getting rain, and second cutting will grow in with first. You will still have the straw seed shafts, but more green vegetative leaf on the bottom. Third is bush hog the field down. This is not a great option as much of the clippings will be in the second cutting, and the heavy thatch will hurt the field, and likely kill a few spots. Basically there is no good solution to what is standing. Next year if you can mow the field when it gets to be about 6" tall, and cut it back to 4". Do this two or three times depending on how the spring is going, and you will delay the maturity of the ograss, and it will have less seed shafts. Your yield will be about 70% of what you will get out of what is standing now.
Very good advice. However, there are some additional "caveats" to what Barry has already offered.
Yes, the "2nd cutting" of Timothy or Orchard grass will begin to grow into the standing first crop. It will be very thick and very hard to get dried out (as well as just getting it cut). And as the season progresses; daytime cooling in the AM and PM increases and the drying periods decrease.
If you can - cut it now and bale it! Good dry forage in the barn is worth alot in the winter - even if you have to supplement it with some added (read store bought) feed.
The added "reseeding" of the mature seed heads that shatter and spread with the haying process is truly a "silver lining"! The thin areas in most fields - along the fence lines or low spots - will have a great chance of filling in and next year's hay will have improved odds of better production and competing with any weeds that are prone to take over those thin areas.
If you're gonna have to brush hog the field - bale it too! Get it off the field. And give it to someone with goats or llama's! IMO - leaving that much material in the field after cutting it up to a mulch consistency is a recipe for significant winter kill.
I'd rather leave the hay uncut and improve the likelihood that the full stalks will not completly freeze into a hard mat on top of the root zones. Even bent over with snow, rain, and ice much of the grass will not "glacier" onto the lower stalks and root tops - leaving a space.
AKfish
