jnjpream
To test the weak battery theory, jump it with a known good battery to see if it changes anything. It's a 12 volt system, so any car battery should do. Just be sure to get the polarity right as when jumping any battery.
I was having the same problem. I stopped by the dealer and spoke with the mechanic and he said to put my tractor in gear and turn the key like I was trying to start it for 20-30 seconds. Put it in neutral then turn the key to start and it should start right up.
I followed his instruction to the letter, and sure enough, it started instantly. I have no switch or light to let me know that the glow plugs are ready or not. I went out there tonight and tried it again with the same results. Instantly fired up with absolutely very little cranking time (1/2 a second...maybe).
That won't make a difference on the BX22's.. The BX22's don't enable the glow plugs while cranking. There is a glow position on the switch, just before crank, that you are expected to hold it in to energize the glow plugs.
For some other tractors, the glow plugs energize when you are cranking. So for those tractors you can put it in gear to disable the starter and allow the glow plugs to stay energized while the key is in the crank position.
One trick I have done with the BX22 on REALLY cold starts, is to glow for 30-45 seconds then crank. Normally on a cold day, without doing the next step, the engine would cough, sputter, and die. So the trick is as soon as the engine starts to cough and sputter, but before it dies, just release the key to the glow position until the engine starts firing regularly on all cylinders, then release the key to the run position and you are good to go.
